Hey guys. Scoured the posts and found a lot of helpful info.. Problem persists.
First time out for the season:
1. DESS key lights up dash, then no dash info. except compass.
2. Long beep after DESS key placed.
3. Starts strongly and runs well up to plane.
4. Loud warning on opening up the throttle for a few seconds. Goes away immediately. Doesn't return if speed is reduced a bit.
After forum review:
1. Battery pulled and checked at auto parts store. "Good"
2. Checked fuse terminals in engine bay and dash. All good except blower fuse. Changed.
3. DESS key without any corrosion.
4. Same results with trial of another DESS key.
5. All visible connections pulled and reconnected. No apparent loose connections or corrosion.
6. No obstructions noted on shaft at grate or at exit.
7. Able to idle indefinitely without overheating. Though, dash info. is never visible. RPM's, hour meter, fuel, etc..
Thank you in advance. I fancy myself a good troubleshooter, but this set of issues has me stumped.
Jeff
After forum review:
Jeff
