2008 RXT255 de-winterizing
DAP
I winterized this thing, flushed the cooling system with air, and can't remember if there's a plug that goes into the garden hose connector right by the jet. Seems to me there was one but I can't find it!!!
Also, how much oil does the engine require for an oil and filter change?
Thanks much
OK, I guess I'm delusional from 6 mos. ago. Thanks for the reply. What about oil type/capacity?
I use synthetic that specifically states it is good for slip clutches due to the SC. Many motorcycle oils fit the bill. Designed for high RPM engines.
Quantity varies based on how much you get out. And if you read the manual you will see there are specific sequences to crank the engine and get more out. This needs to be done in "flood mode."
Got it. Thanks. I just ordered SeaDoo 4-stroke XPS Syn Blend. And a filter and o-rings. And an extractor pump. All good.
