Trying to trouble shoot my brothers GTI 130. Rough at idle (1200-2100) 5 min warmup- 1500-1800 back to 2100, 1/4 throttle chugs (rough no back fire) 1/2 throttle 3800 - 4600 rpm rough periodic drop to 2900, 3/4 throttle - oil waring light comes on with constant beep RPM 5000 - oil warning come on almost immediately when hitting 5k. Of Note: engine warning light does not come on, and oil warning only comes on hen the motor hits 5k.
Th Seadoo has new gas, oil at spec, was serviced by dealer in the fall. Rough first start up, changed fuel problem persists. Dealer changed the starter solenoid this springs because of a starting issue. Battery was charged to full at spring service. Plugs all looked normal.
I hope this helps you experienced guys. Could use a starting point for diagnosis.
Thanks all
Thanks all
