Hello. My 2007 seadoo gti is having a problem with the hours gauge. It is stuck between 80 and 81 hours. It had been at 80 for a whole then moved to 81 and then back to 80. Any ideas?? Thank you
If load test means putting the ski in the water and running it works perfect sorry I'm not to good with technical but now that u mention the battery I did see a 12 v low warning for just a couple seconds then it went away. A bad battery can cause this ?? Thank you for helping:cheers:
you would be surprised what a bad battery will cause in these skis...it sounds to me like you have a bad battery but take the battery out and bring it to your local autozone or auto supply place and have them test the battery... odds are the battery is going to be bad
