No Carb (injected) is the 215 engine with a SC...
Take a GOOD look at the hoses going to the SC. See if one is cracked or off or has a loose clamp. If so, fix that.
If not,, remove the hose going into the SC. Reach in with your finger and see if you can turn it. It will be VERY hard to turn if all is well.. If it is easy, then the SC is done.
All that said,,, the 2007 model had Ceramic washers in the SC. These washers are a major issue. Unless you have paperwork frm the previous owner (PO) that shows these have been changed, you MUST replace them.
Officially the SC needs rebuilt every 100 hrs. SO,, if you are over 50 or so hours you might as well rebuild the entire unit now and hten be good for the next 100 hrs.
When it is rebuilt it will get STEEL washers. The issue with the ceramic washers is, they fail and he ceramic parts go into the engine and DESTROY it...
