Hi Guys, new here.
Looking for some advice and help if possible,
So the GTX was running great, just had a low battery before. In the process of changing to a new battery, they mechanic accidentaly reverse polarised the poles ( to the point it was mounted and bolted to the battery already, nothing happens, checked a bit, and only then noticed they were on the opposite side). After put it back correctly, jertski was absolutely DEAD. Nothing happens whatsoever even with the key in.
What we have done:
- ECU replacement (bought a Candoo Pro system and could not detect the old ECU)
- DESS post replacement
- Cluster replacement (was due) and married to ECM
- Went through all relays and fuses, tested each one and was OK
- Went through all harnesses, checking for connections on all the cables, was OK
Observation:
With the new replacements, there seems to be power traveling from the point of contact from the key. Cluster turns on, does a Welcome to Seadoo, you hear the fuel pump, and also a valve opening. Then the cluster blinks, and repeats, does not stay on, and no buzzer sound or response from the Start/Stop switch.
What I can confirm is that there is power from the DESS post to the ECM. But it seems there is no command from the ECM to the Starter Solenoid/ Relay. No clicks or anything. Start Solenoid when jumped works fine and clicks normally.
So now I am completely confused what else could it be..
Any helps, tips, advice would be greatly appreciated!
Cheers
Chris from Indonesia
What we have done:
Observation:
Cheers
