2007 GTX Speed Sensor Not Working
Kpvalentine
Hello all,
My speed sensor is not working. gauge does not read speed at all. I checked the sensor - The wheel turns and I have checked the volts. it is getting 12. and when I turn it 90 degrees I get a fluctuation in volts. I have checked it on buds and it shows no problems and the right boxes are checked.
Is it an ECU issue? a wiring harness problem? any ideas are welcome!
thanks
Thanks ski-d00 again! yes it is an ECU issue. I took the ECU from my other ski and hooked it up, married the gauge cluster to it, and the speedo starting working perfectly.
