Davidgtx22
Good Day everyone.  This is my first post to the forum.  I just purchased a 2007 GTX 215 Limited.  The display is burned out which I understand is normal for these due to sun exposure.  My ski starts and runs fine but my problem is that when you pull out the dess key when engine is off it will give a short beep followed by long beep.  It will do this every 15 seconds or so.  You can also here a servo motor near gas tank cycling through with each beep.  Ultimately my guess is it will kill the battery so in order to stop it I have to either disconnect dess connection under the hood or pull battery cable.  I read in the forum that this pattern of beeps is referencing diagnostic mode.  Any thoughts on how to correct this?
