2007 gtx 155
Hello I have gtx 155 2007 I have no dash no beep no start dash does start up sequence when putting on key then goes out can hear fuel pump going and if cross over on solenoid it will roll over just fine any ideas
Still no luck I have replaced the relay dess post starter button and starter solenoid fuses are good new battery cables can’t think of anything else any help is much appreciated
Check your grounds; then put a multi meter on the battery; What is the voltage with the key off the post and what is the voltage drop when you install the key?
