so I am helping a neighbor with his ski. started out with a busted front cowl that the dealer said they could not fix. I fixed it with epoxy and pop rivets but then the thing wouldn't start. been sitting in a boathouse for couple months after running fine. no beeps, no clicks, no nothing. charged the one year old battery. still nothing and the battery has 12.6v. I told him to take it back to the dealer. they told him it needed a dess post but the part was NLA. I got him an aftermarket post off ebay, he takes it to the dealer, they install it, charge him $800 and it still won't start. the dealer says it is PROBABLY a bad ecu and they don't want to work on it anymore because it's too old. so now it is in my workshop. I have cleaned all the grounds, taken apart/cleaned all the electrical plugs I can. bench tested the solenoid and the relay (good). shorted the solenoid terminals and the engine cranks great. tested all fuses with a multimeter. inspected the back of the fuse panel. removed/cleaned the battery cables. swapped in a different battery. the old dess post tests the same as the new one (resistance per the shop manual). the starter switch tests good and I can hear the fuel pump come on and shut off as it should. what I get now with the key on the post is one long beep and no crank. the dash seems to come on but is very dim (the owner says it always did that)
I don't know much about jet skis but have worked on a lot of cars/boats/motorcycles and at this point it seems crazy to throw $1000 at an ecu for a $2000 machine. Is that where I am at now?
thanks
Randy
thanks
Randy
