Short version:
Engine starts fine when cold and hot, but issues when warm. It will crank over but will not ignite. After about 20 minutes then it finally catches and starts.
Long version:
I bought the Sportster last year used. Has always started right up (cold, warm, hot). Even this April after sitting with the fuel tank full it started fine (but was rough running for about 30 minutes because of the 6 month old fuel). I took it out 3 more times each time adding new premium fuel (and Sta-bil to each tank). I have easily run through 2 tank fulls before the new issue started.
The issue started AFTER my last trip to the shop. They installed a CD player and adjusted the shifter linkage. I don't think it is related to the issue, just presenting all facts. This past Sunday I took the boat out and ran for about 2 hours. We anchored and shut the boat off. When the time came to pull the anchor the boat would turn over but would not ignite. I took the engine cover off and checked every possible electrical connection I could find. I tried and tried again to start. Each time waiting a few minutes in between. A few times the engine would make a strange "puft" sound. After doing that a few times it finally started and off we went. I thought a one time thing so we went for about another hour and decided to test it. We anchored again. Shut the boat off, waited a minute and started it right back up. Great we thought. 45 minutes later we are ready to leave and once again it would not start. Turns over but did not ignite. Again waited and tried. "Puft" sound a couple of times and it finally started after about 10-15 minutes of trying (thank goodness plenty of battery power).
So...any ideas? I told my local shop about it and the tech said he would ask around. Well, 2 more calls and 4 days and no answer yet. Any advice would be greatly appreciated. Thank you!
Long version:
