I recently purchased a 2006 gtx with 6hrs sitting forever, starts up with carb clean
The clusters giving me a code for fuel pump which I already removed and is bad
I’ve ordered so it seems the cluster is working
The MPEM bottom right plug (#1) had corrosion which I cleaned
But the cluster still turns on when I connect the battery, I’m not sure what turns the cluster on MPEM or the ECU
Which one houses the power supply relay
When i connect battery 1 short beep 1 long beep it just keeps on beeping
Plug the key on and will get the 2 beeps
I read one post on here similar but no answer/fix was ever answered
Jason
Jason
