2006 GTI standard
Riley611
Good Afternoon, here's my issue. Ran it all summer 2016 no issues, stored it as I have always done with no issues. Took it out yesterday from the garage, check the charge on the battery (Full), check the fluids all are normal. did a visual inside and out all checked good. plugged in the lanyard got (1) beep then nothing...... checked all the forums to reset the lanyard post (5) times engaged the start stop switch still no beep. Checked the instrument panel power is good from the battery all indications are good except will not start and no beep indicators. Thanks amigos
computer not reading the key.start simple clean the post and key first . Then disconnect the battery terminals and clean the cables and battery if the post doesn't work. Also did you try the learner key?
If it continues to say reading key and means that it is not sensing anything on the D.E.S.S. post maybe a bad post or bad connection
