2006 GTI Base seems to be taking on alot of water ...
BMANN06
Seems that if this ski is wet docked overnight it gets enough water in it to touch bottom of engine? This normal? Thinking of installing a bilge pump but it's got a small battery in it. Anybody else find this a problem? I've filled the hull with garden hose and can't seem to find leak. It also takes on quite a bit of water when ridden hard.
Any ideas?
Found it ... it was the seals on the "turn flappers" (for lack of a better description). Little RTV sorted it!
SDB ... I don't think so. It's a pretty technical term. I think you'll only find it in the senior engineering documentation at BRP ...
:rofl:
