inspectorsmith
So i just got this 2005 Sportster le di, i new it had an electrical problem just wasnt sure exactly what it was. I dont have much info on what happened, owner said they were cruising around the lake everything was good as they got back to the dock it just died. They didnt want to fool with it, so i got it for what i think was a good deal, i may be wrong.
Thought is was going to be a simple fuse, but maybe not. opened up the electrical box over the pump it had about 1/2 inch of water in it. So i took it apart and cleaned and greased everything. Checked fuse at battery, main fuse, and all the fuses in the control box, they are all look good. I have power to the bilge fan and the bow light but nothing else works. No beeps from the key, no gauges, does not start.
I do have power from the battery to the control box and at the voltage reg, and the grounds look to be tight.
Need some help, is there a fuse i missed. Hope its not the control box.
any help
any help
