Mpincince01
My 2005 Sea Doo RXT Fuel Gauge stopped working. Tested the sending unit and it gives the proper resistances. Tested the cluster by applying resisters inline, and the cluster also tests as good, and gives the proper fuel level readings with the proper resistance applied. All sections of the wire harness were tested for breaks, and all showed good continuity. So, I assume it's my ECU. Everything else works as it should, but there doesn't appear to be anything else in the Fuel Level schematic. Is there anything I'm missing? And, if not, do I need to replace my ECU, or can it be repaired by just having the dealership re-flash it? Any help would be greatly appreciated, and Thanks in advance.
