RobertMilos
Recently i picked up a seadoo rxp 215 which was previously sunk, but all the water was taken out. I got all the water from the air intake out, then i started the engine no problem, the engine had oil. it fired up all good then i took it out to compression test it. all the cylinders had around 100 psi( 5 bar), which means it need a rebuild but this is not the problem. the last time i tried to turn it over from cylinder 1 a lot of fuel come out then nothing. Whn i plug the safety lanyard after some seconds i hear a long beep. I need to mention that the gauge cluster was never working.
Any opinion?
			Any opinion?
