kEVIN McCARTY
Hi all I have a 2005 rxt 215 hp that shows overheat condition and one constant beep and goes to idle until you shut it off and back on.Then it starts right back up and runs fine unless you go over around 5000 rpm. It is not overheating and the fluids are ok and no blockage that I can see. The wierd thing is it does not giving me any error codes at all. Am I not waiting along enough time when it fails before shutting it down and then starting it back up? I'm guessing it probably is some temp sensor issue? Anybody ever have this issue? and how to fix it? thanks Kevin
