I am trying to figure out the problem with my Seadoo.
At first code 1682 was showing, I would not start.
The next day the screen died and nothing was seen. What it does is one long beep. It doesn't matter if the DESS key is on or off, it does the one long beep.
If I disconnect the battery, upon reconnection of the battery, The one long beep sounds, but nothing else.
Already check all fuses and they are ok, removed the wire harness and check it and it looks fine. I have two DESS keys and it does the same thing with either one.
I believe that is either the MPEM or the ECM or both.
I need a little help.
Thank You!
Thank You!
