romerodt1209
Hi, new to seadoos, bought a 2005 Challenger 180 SC knowing it need some TLC before this season. Doing an over haul of the drive system, new carbon seal, solas impeller, polish drive shaft, jet pump rebuild, etc. Ive run into issues with the wear ring. The first one i bought was a titian aftermarket which had an ID to small (OD was the same) and the impeller would not fit. Then i ordered a OEM PN 267000372, and it the ID and OD are larger then the old wear wring im replacing. How much shrinkage can i expect because it appears (before getting cold) that its to big to even fit in the housing???
thanks
thanks
