tbusic2004
Newbie to the Jet boat world here. Sorry about long post but I have tried some stuff and may be creating problems. It was running fine first half of summer after buying it, and replacing battery and some cooling hoses.
Then went into what I believe is limp mode. Engine started and sounded fine but wouldn't go more than 5mph and long beep about every minute. Took it off the water and started it on the hose a couple times and seemed fine and would rev. Did some research and started again to measure voltage at battery to see if it was charging and time the beep, but then it died before I could get the multimeter on the battery. Wouldn't start again and battery was clearly dead.
I figured dead battery probably b/c of bad rectifier or charging system. Charged battery with plan to start and measure voltage to battery. Now, it won't start. Replaced plugs and getting good spark at both. I can spray some carb cleaner in behind them and the engine will briefly start.
So I figure fuel delivery issue now a problem too. I noted that the fuel pump doesn't make a noise like it is priming as it used to. So I order the HiFlow fuel pump in the tech manual by Sticky and installed it. Noted that the washers came out before I saw the order in the cannister. I have it from outer: Outside filter, cannister, rubber washer, metal washer, inner filter, grommet and then fuel pump. May have reversed the rubber and metal washer I am afraid. The darn spring also popped off and disappeared into the engine. Looked for an hour with no luck. Bought as close of a replacement as I could find without ever actually seeing the thing. New spring may be too hard to compress if anything.
Put the cannister back in the tank. Now it primes, and clearly is delivering fuel but won't start. Good spark. Took off fuel injector and it pulsates squirting some fuel when trying to start. I just don't know if is enough or if there is another problem. Seems like gas + spark should = fire in engine.
Problems I am suspicious of:
1. Reversed washer order in cannister slowing fuel.
2. Spring too tight.
3. Do I need to fill the fuel pump cannister with fuel or pressurize/bleed lines somehow?
4. Black cannister fuel filter in fuel line could be plugged. Champion G6384 part number but Google search shows nothing like it for sale. Also, I am not sure how it is attached and don't want to just rip it loose. Doesn't seem to scew off easily.
5. Fuel line problem. I don't have a tool for the fuel line quick connects. Any workarounds?
6. Injector problem.
7. Beats me if none of the above. Once I get the thing to start I still need to check the charging system. I am cautiously optimistic a failing fuel pump was drawing a lot of amperage and killed the battery, but I don't know if that is possible.
Any help would be greatly appreciated.
