2004 Sea Doo GTX 4TECH SUPERCHARGE 185hp very good condition,blowen motor,so it needs an engine.I dont have the funds to fix it.Like new 2006 arrow trailer with deal.$2,700 obo 786-347-6173 joe or I can part out,let me know what you need,everything is good but the motor lower end.
2004 Sea-Doo GTX 4-TEC Supercharged
GTX 4-TEC™ Supercharged, the industry's highest horsepower three-seater* and the perfect combination of muscle and size for you and your family. Beefed up performance comes courtesy of its renowned GTX hull and 185-horse supercharged Rotax engine. You get zero turbo-lag. Maximum responsiveness. And a gang of useful features, like a 16-function information center; Off-Power Assisted Steering (O.P.A.S.™) for additional maneuverability; and a folding reboarding step. An exciting new look makes the best selling four-stroke of 2003 even better for 2004.
MANUFACTURER Sea-Doo
MODEL YEAR 2004
MODEL GTX 4-TEC Supercharged
M.S.R.P. * $10,399.00
ENGINE & DRIVETRAIN
ENGINE Supercharged four-stroke, three-cylinder Rotax® SOHC, Closed-loop cooling system
HORSEPOWER 185 hp
DISPLACEMENT 1494 cc
BORE X STROKE 100mm x 63.4mm
COMPRESSION RATIO 10.5:1
CARBURETION Multi-port fuel injection
IGNITION Digital inductive
STARTER Electric
TRANSMISSION Direct drive, forward / neutral / reverse
OTHER
PUMP Comp / alum, axial flow, single stage, large hub with 10-vane stator
IMPELLER Stainless steel, 4-blade
PROPULSION SYSTEM Bombardier Formula water jet pump
LUBRICATION Dry sump, pressure oil system
OIL CAPACITY 4.5 L
BATTERY 12 volt
MEASUREMENTS
LENGTH 130.9 in.
HEIGHT 44.4 in.
WIDTH 48.2 in.
WEIGHTS
DRY WEIGHT 867 lbs.
OPERATIONAL
SEATING 1, 2 or 3 riders
FUEL CAPACITY 15.9 gal. (incl. reserve)
BODY
HULL MATERIAL Fiberglass
HULL TYPE Modified Vee
STORAGE 52.6 gal.
MODEL YEAR 2004
ENGINE & DRIVETRAIN
HORSEPOWER 185 hp
STARTER Electric
OTHER
OIL CAPACITY 4.5 L
BATTERY 12 volt
MEASUREMENTS
LENGTH 130.9 in.
HEIGHT 44.4 in.
WIDTH 48.2 in.
WEIGHTS
DRY WEIGHT 867 lbs.
OPERATIONAL
BODY
STORAGE 52.6 gal.
