Secluesioned
I have traced everything that I know to do. Heres the list Please read everything and help if you can!
Stator giving 20-75 Volts AC 20ish idle. higher I rev higher it goes. All 3 yellows have continuity between them and none have continuity to ground. So stator seems OK
All wires gone over, removed, and all plugs taken apart looking for corrosion but found none. Cleaned and electric grease used.
Checked all fuses. When I got the ski it had the charging fuse melted. Not blown. But the plastic was melted. I replaced. pulled the pins and squeezed the pins so it made a snug connection with the fuse blade.
Have killed 3 OEM rectifiers. With a new rectifier in it charges 13.6 -13.8. Never goes to 14 with revs.
After 3-4 hours of riding the battery is dead and the rectifier bad.
I can have a new rectifier in had. put it on and get 13.6-13.8 charging (but never increases with revs) and then put the other one on and only battery voltage. no charge. put the new one back on and charging.
I may have found the issue, But need more input. Please see picture. The Plug circled in picture seems to lose connection at times and when the key is put on it does nothing. If it is losing connection while riding, it is not killing the machine. Only ever have an issue when you shut it off and try and start it again. But when it does lose connection you can touch the plug and you hear the sound of a relay click and the ski beeps. The circled wires appear to be the power and ground that go to it? Im not sure. But this is the MPEM and I seen a post on here <<<<<< that explains how to see if the MPEM is bad. From that post it is not. So I am assuming the harness is bad?? But would like more info. Or if anyone reading this has a harness AND mpem they want to sell, Id buy them. But on that I have a question. Does the MPEM replacement require a dealer trip?
I just dont know what else to check on this thing.
Any help would be greatly appreciated. Just trying to figure this out.
