bearworley
2004 GTX 4-Tec S/C Jet Pump Maintenance Question
Hey guys,
I just recently tackled my first jet pump maintenance check as the guy I bought the ski from had not done it as best he recalls. I am the third owner, and the ski has 128 hours on it. The forum provided a lot of great info and pics to allow me the confidence to go it alone, and it was not near as nerve racking as I thought it would be. One hesitation I have, now that I'm done, is a question about the amount of grease (recommended vs. oil in this model) in the cone. I purchased a couple of tubes of the SeaDoo jet pump grease at a local dealer and used only 1 tube. The cone was pretty full and the grease that was inside looked really good overall (using pics of grease exposed to water as comparison) but I cleaned it out and put new stuff in since I was in there anyway. The o-rings and bearing were slathered in grease as well and everything looked good there too so I just added a little bit directly to that area. The other thing I did not do (realizing after I was done) was seal the nozzle assembly against the pump housing with any 518 sealant or similar. There seemed to not be anything there when I took it off so my brain was not thinking about it as a necessary replacement at the time. I did use the blue loctite on all the bolt threads to ensure a good seal there but before I start this bad boy back up should I go back in and add grease and/or 518 sealant to the housing? Once the job was completed I lubed everything else and checked my other fluids etc so she is good to go for my next outing as best I can tell. I'm not afraid or worried about getting back in there if I need to, but I just thought I would ask before I do so since you guys are so awesome at making us new guys feel a little less...ummm challenged
Thanks again for all the help and info! This has been a great resource!
Brian
Hey guys,
Brian
