I have a 2003 GTX Limited with ~150 hours on it. I am not having a problem, but having read all the problems with the superchargers, I decided to look at mine. I took the inlet hose off and found a small amount of engine oil in the hose and inlet. I measured the slip moment of the clutch at ~5 ft-lbs which is right in the middle of the range. I removed the SC and the one part in the clutch I can measure without taking it apart is the locking ring and it is at 6.99mm or right in the middle of the "new" range. There is noticable wear on the gear teeth, but the unit spins freely without much slop. The ski is not used at WOT much and probably has not unlocked going over waves more than 20 times during its whole life. So the question is, does the SC just need a new oil seal or does it need to be rebuilt?
