Hello all, newb both here and to the Sea doo jet boat world. I have a 2003 Sportster LE 2 stroke that ran great for about month after I bought it. started getting water in the engine bay one outing and had it checked out, turned out to be a bad bellow and hose clamp... got those replaced and got back in the water, all was good. Then one day it started... died and no electrical... checked battery, battery switch, fuses in fuse block up on bulkhead behind center seat... nothing wrong. Finally tracked down the 15amp fuse in the rear electrical box and sure enough, it was popped. Replaced fuse, everything worked... took boat out a few times all was good. This weekend, took boat out, run throttle up, got on plane, cruising along, boat died... no electrical. 15 amp fuse popped again... replaced. Boat started, run up throttle, started to plane out, boat died... fuse popped.
I can replace the fuse and the boat will start and run great... idle, no problem... putt around at 2 to 3000 rpms... no problem, throttle up to get on plane, fuse pops... looking for ideas on where the problem might be. Thank you for your time.
Bill @ Eufaula
Bill @ Eufaula
