2003 rxdi fuel return problem
Have a 2003 rxdi ski was doing dumb stuff so checked the fuel pressure and with just putting the key on the post the pressure is well over 100psi probably around 150psi but not sure the gauge only reads to 100psi but was told that with just the key it should only be at 27psi so I took the return off and it flows back to the quick fitting after that it doesn’t go any farther I’ve tried blowing in it with the air hose and still doesn’t allow air back into the tank any ideas?
