PabloCruz
My gauges are not working long beep then short beeps, so I have read a few forums and have spent hours going through the electrical with no results. The machine operates excellent, performance is there, used in fresh water, never sunk, new battery with proper voltage. I have checked the connector up front behind the panel in storage area which feeds the gauges, the power wire shows 2.5V to ground (low), the power I have learned is the purple wire going to gauges at this plug however the feed from the harness or other half of plug is white with red, I have chased this back to the MPEM plug 1 and wire is good back to plug up front. Pins in plug 1 had some minor corrosion so I carefully cleaned all pins, and tried to clean sockets in plug (tough to do) still nothing, all pins are straight no misalignment. I have checked with DESS plugged in for power at 2 amp fuse it is there and drops out when key is unplugged. I have also checked the 1 amp fuse at plug 2 with and without DESS and same. So I have come to some conclusions
1) Socket for the white with red wire in plug 1 is bad not making good contact with pin, the socket does have continuity to front I used a pin in the socket and checked to front plug.
2) I am just guessing here but could DESS key, even though works as does the learning DESS, cause the gauge 12Volt feed to not come on, could just replacing DESS fix the issue.
3)MPEM 12V feed to gauges is bad (replace MPEM)
So if I have voltage at fuse when DESS is plugged in does it just go to through fuse then to pin at plug 1 or through electronics in MPEM then to pin.
I am pretty certain gauges are good and not getting the 12V so my big question is, what do you guys think is next step, DESS, MPEM. Can I unplug plug 1 on MPEM and using DESS key see if I have 12 volts at pin feeding white with red to gauges or with plug 1 removed does everything go dead. My brain is fried and I knew a new MPEM would fix it I have no problems buying one rather be DESS though LOL. Any help will be greatly appreciated.
