Ghathaw
Thank you for investing your time to read this.
I have a 2003 GTI LE RFI that I finally got running on land. When I run it on land with a hose connected after starting everything is great! this past Wednesday I took it to the lake and put it in the water. Since this was the first time I had it on the water I pulled both seats and checked for any type of leaks. Finding none. I pulled away from the dock and it "sputtered" a little but I expected that, being it has sat almost a year. I didn't want to push it hard so I took it to approximately 35-40 MPH. Things were going well but I noticed it seemed to begin to "drag" a little. Eventually after about 5-10 min of riding I noticed it was sitting lower in the water. Having bad carbon seals in a former ski I knew I had to get back, and I could only reach 6 MPH then. eventually it stalled and like all of us a little "trickle" can seem like a flash flood and by that time water had reached a level where the back end was slightly under water.. We hooked a rope to it and towed it back to the ramp. Hooked to the trailer we pulled it out looking for any sign of leaks coming out with water inside the hull..."NOTHING. I drained the water, backed the trailer back into water and searched for leaks. NOTHING. Started the engine and water seemed to "flow" from under the left side (facing front on the ski) of the engine. Shut off the engine and rode the other 96 GTX (what a battle horse) and headed home. Hooked it to the hose, started the engine, turned on the water and NOTHING. no water, no leak.
Here is what I can tell you:
No leaks with the hose and there is a stream of water coming from the left side out the small opening.
No leaks from the inside out.
No leaks under the exhaust. The hoses all seem to be properly connected.
With the hose hooked up I see the "pee trickle" squirting from the left side. There are two openings but only one squirts. (I think the other one is ventilation for the battery.
At this stage I've not pulled anything. I've talked to two pretty good mechanics and they tell me the hose test would allow water to exit the muffler if the freeze plugs went bad.
I don't think the motor has frozen but I cant tell for sure.
Keep in mind she runs like a champ out of the water.
Thanks ahead for all your help.
