Hello guys, i'm confused on how to install the water lines, i have the Flush Hose in the (Out) arrow, and the other line in the (IN) arrow, attached there is a picture that is not mine so you guys have an idea, thanks.
When you flush these skis on the hose you are running the cooling system in reverse to blow out any sand and shells that can clog the cooling system.
Remember you can only do it for a few minutes so you don’t burn up the driveshaft seal.
Also it’s always engine on then water on then water off then engine off. If the water is ever on with the engine off you will force water into the engine and ruin the engine.
