Sportster-2001-951C-Stock
Nice! 6700RPM - I think there's a bit more on the table to be had. Are RAVE blades completely CLEAN? Do you feel a burst come in about 80% throttle, I think that one likely has the throttle position switch (TPS) in the throttle cable at the "Y" where the throttle cable splits into two (A->carb B->oil pump)? The signal from the TPS to MPEM adds ignition advance.
Also, did you set the HS mix screws to closed, or are they open? In that case it could be too rich.
