2002 Utopia 205 Broken Wire - where does it go?
RondoSymbo
Premium Member
Premium Member
Still working on the rebuild of my 2002 Utopia 205 and sorting out damaged wiring. I am down to this last wire without a home. One end is on the slave solenoid, but I can find no remnant of where the other end terminated. Any guidance on where this wire may go would be greaty appreciated.
That looks like a home-made wire to something/somewhere that no longer exists. Maybe to a house battery? It would be HOT all the time that the master switch is ON.
Thanks, Tim75. I had not thought of that possibility.
Trying to determine if maybe it is supposed to go the starter as shown in the images below. But I cannot confirm the correct gauge, if it is. Nor can I figure out why it would be used, in addition to the direct heavy-gauge main feed from the battery.
My confusion is that one image indicates a black wire (no gauge shown) and the other an 8 gauge red wire, so I am a bit baffled. Hoping that someone will have a similar wire with both ends intact.
