Yep... what he said. NO as a "Bolt in" project. With that said... anything can be done... but you better be good with working with fiberglass.
The only things that will bolt in are other "Sportjet" engines. (240 gen1/2, 210 carb, 200 Opti) You can bolt in the 250 Opti, but you need the entire drive also. (it had a different gear box)
With that said... all the 2.5L outboard parts can be used to rebuild what you have. The only thing that isn't the same is the splines in the sportjet crank. SO... that has the be reused. Performance Marine can weld, and regrind your old crank.
