steve.smith@esker.com
Hi everyone. I have a 2002 Seadoo GTX-DI which has been a great machine until this year. The first problem is it suddenly is draining the battery. I took it to two authorized Seadoo dealers, the first put in a new battery (which didn’t work), and the second suggested disconnecting the battery after every use (they could not find the source of the drain, but did detect it). That works, but is a pain. My latest issue is I’m getting a Maint warning every time I accelerate, and it goes into limp mode (max speed around 35 MPH). When I idle, the maint light goes off. I accelerate again, and within a few seconds the maint light is back, and I drop to limp mode. This only happens with the Yellow or fast key, the white one works fine. Any ideas for either issue? So far I have been unimpressed with the BOMs system, because it does not seem to tell the dealer too much. Any help would be greatly appreciated. Thanks
I keep trying to reply, but it never shows up. Thanks to everyone for your input. I can see how the rectifier will help my battery draining issue, but will it fix my issue with the maintenance light coming on when I accelerate? Again, when I accelerate, it comes on and drops to limp mode (about 35MPH). When I go back to idle, it turns off. Pushing in the Mode/Set keys does not clear it. Do you thin the recitifier will fix this?
