2002 Sea Doo GTX di
RMD419
I have 2 of these jet skis with what appears to be the same issue. Won't start. If I remove the pressure hose running from air pump/compressor to green solenoid valve part #270 600 044 the ski will start and run. What could potentually be my issue with these skis?
The ski should not be easy to start with the "small hose" disconnected. It the compressor will not be able to maintain fuel pressure with such a large leak. May have a hose issue or solenoid or something else connected improperly. Check fuel pressure.
