2002 gtx water in cylinders
nhfoam
I have 2002 gtx 4 tec sea doo I am getting water in engine I jest bought it it started up fine but when I put the hose on it and ran it after shutting the motor off the motor hydro locked and would not restart I was abel to get all of the water out of the cylinders and re start it without the water on dose any one know what's caused this or what the fix is the motor only has 49 hours on it
El Toro 33809
I am not sure of the proceedure on the 4-tec engines, but with the 2-stroke you run the engine before turning on the water and turn the water off before shutting down the motor. Is that the same as the 4-tec? You would probably get more and quicker responses posting this in the 4-stroke PWC section of the forum.
