HateMyGTXDI
Hello,
I'm new this forum and see many helpful people. Hopefully someone can help. I've searched the forums but don't see my exact issue. I have a 2002 GTX DI that is in some sort of limp mode until I get the throttle in just the right position, then it will take off, but only up to 35 MPH. I know this Seadoo should do at least 55 MHP and more, but mine won't.
Here's the situation:
I bought it used about 8 years. It ran pretty good when I first got it, but then it sat for a while. After taking it out again last season, and this season as well, it definitely goes into limp mode. Upon starting it, it beeps twice (which I think is right) and then one long beep. It's flashing "low oil" so I'm assuming that's what the long beep is. I have addressed the low oil. No other Maint Lights or beeps. It will start fine, both on the trailer and in the water. It will usually idle fine in the water but when I push the throttle, I won't go over 4000 RPM's and not over 10 MPH. However, when I get the throttle in just the right spot (Sweet Spot) it will take off. It will get to 5500 RPM but only about 35 MPH and run OK for a while, but if I go past this sweet spot or before that sweet spot, it will again bog down to 10 MPH.
I have:
Checked voltage at the battery:
12.0 volts before start
12.8 volts while running (seems low to me)
Charged the battery
Changed Spark Plugs
Pulled the injector assembly and watched them spray. It seems like a good spray and both seem even. I plan to pull them and clean them
Replaced the air solenoid valve
Replaced one-way check valve
Checked compression: 115 at both cylinders - Is this low?
Checked fuses all good - I read there is a 1 amp fuse somewhere but can't find it
Checked wiring harnesses and all seem tight
I have not put a Candoo Pro on it yet to see if there are any codes.
I have not replaced the TPS's yet but suspect this could be one of the issues.
I have not pulled the RAVE valves yet, but plan to. I had trouble finding the right gaskets.
Someone replaced the fuel pump recently as a "favor", but I'm sure it wasn't an OEM fuel pump. Not much of a favor. This may be causing the problem because of the amp draw, and the fuel filters were replaced by same person.
I know many have experienced the limp mode issue, but has anyone experienced this issue where the sweet spot allows it to run? Any suggestions would be great!
Thanks!
I have:
Charged the battery
Changed Spark Plugs
Thanks!
