Long post, sorry it’s a DI…
New problem. Finally got the 2002 GTX DI working last fall, just a little slow at 40 mph indicated and 6540 rpm.
Had the mechanic winterize the DI last year as I didn’t have time. This spring cleaned and rebuilt raves with OSD kit. Put it in water and Starter would not run, no solenoid click nothing. Plug in DESS and get two loud beeps, Electric pumps make noise. Push starter button and fuel pump whirs but no starter. Starter DID work when solenoid jumped. Replaced solenoid with known good one, no change. Added battery pack jumper (12v sla only, no car or alternator) no change.
Tested low amp solenoid leads:
Starter Button not pressed
Black=+12v
Yellow with stripe= ground
Starter button pressed no change.
removed rear electrical box checked for shorts, small amount of water no wiring issues.
Checked electrical plug connections, ok.
rectifier is new OSD heavy duty 4 stroke one .
All fuses in mpem and rear box checked and ok.
so now the kicker, I tried to see if it would start if I jumped the solenoid with the spark plugs in. Starter went dead after three cranks. Now no sparks at all when jumping the new good solenoid AND the maintenance light finally turned on.
AFAICT I have two problems:
1) There is some type of electrical fault with energizing the solenoid.
2) I fried the starter somehow trying to start it.
Any help with the electrical?
Fried MPEM?
One of those haunted electrical things that only a NEW battery can fix?
Black=+12v
Fried MPEM?
