lamajama
Hey everyone,
I've got an issue with my 2002 GTX DI that I just got. I replaced the battery and it's held down by a
larger "harder plastic" strap that is bolted at each end of the strap into the bottom of the seadoo.
I noticed taking off one side that the bolt came off rather easily....and in trying to put it back on it appears it was already stripped (which is why of course it came off so easily...:ack
EDIT: After looking at the parts manual it appears that there should be a bolt protruding from the
bottom of the seadoo and you unscrew a nut that is holding down the battery strap - not a bolt
as in the above description. One side currently has this bolt protruding out but the problem side
does not - so it appears the previous owner attempted already to repair this issue by screwing down a bolt instead of attaching a nut like it should be OEM.
So now the obvious issue is how do I either repair this side so I can rebolt down the OEM battery strap, or come up with a "fix" to secure the battery.
A bungy cord/strap will not work as there is nothing to attach the cord to to create any tension, and I have to be able
to remove this bolt in the future so that leaves out a permanent fix.
Any thoughts?
Any thoughts?
