Ok so i have been working on this project and I am down to not having spark on cylinder 2 and 3. I have checked CPS 240 ohms at pins 5 and 19 "A" harness ECU and 2.4vac while cranking checked at the 2 pin connector for the sensor. I have checked all the coil packs on cylinder #1 and they are good. I have checked for dc voltage at each coil and had 12.4 vdc. I removed the injector rail and cranked the ski witnessing all injectors firing, I assume the injectors are firing based on info from CAPS and CPS if this is true then both those circuits are good allowing injectors to pulse. I am almost convinced i need a new ECU.
If I replace the ECU with a used one do i need to make sure it comes with the keys?
If i install a used ECU is there any thing else that has to be done as far as programming?
If programming needs to be done can that all be accomplished with Candoo system?
