smblackmon
Oil appears to be entering the intake system by way of the bypass hose from the crank case to the intake manifold. The resulting fuel air mixture is adulterated by the large amount of oil causing smoking exhaust and irregular running.  The bypass hose should normally contain only vapor fumes which would burn as part of the fuel air mixture. The amount of oil being diverted to the intake is very large.
I've had it in several shops and they replaced a check valve which is supposed to prevent oil from entering the intake which was costly and did not correct the problem. Another shop now wants to pull and dismantle the engine to diagnose the problem. Not sure I want to spend this kind of money.
Engine has only about 150 hours and compression tests are within spec.
Anyone ever experienced a problem of this nature?
