fender1983@gmail.com
I found that my bilge is leaking. It appears that the leak is coming from the swim platform where deck and hull are joined together. It is most obvious when i back the trailer into the water, when swim platform goes under water i can hear whater stream rushing in.
When i am on the lake, the waves hit the joint and water will get in the bildge.
Any suggestion on how to fix or at least reduce the leak?
P.S. I am also planning to intentionally flood bilge with garden hose on the trailer with approximately 80 gallons of water (i had 4 guys on the boat on the trailer drinking beer when i bought it, so, i figured i can put equivalent weight of water in the bilge without ruining my trailer) - this method would test lower through holes for leaks too.
