Hey Bonmotwang, I will be at the Children's festival tomorrow in Oakville, might see you there. Wish i knew who you were as i would love to hear the stories of this boat. I just started reading this thread last night.
	So I like to turn the oven on to 200*f after I wash a freshly bored cylinder and let it heat up to temperature then shut it off. I wash the cylinder, dry it with compressed air and place it in the oven to dry for half an hour then oil it down thoroughly with wd-40 or fogging oil until I can get to it for final assembly.
It makes 100% sure the cast liner is dry before it's oiled and works really well if you're going to be more than a few hours until assembly.
Your good using water that hot is key to getting it to dry so quickly before oiling. I only bake them if I'm waiting on parts or going to be a few days until assembly.
Looks like you still need to clean that old gasket staining off the cases?
Use a scotch brite pad to remove gasket residue, (green or red) nothing else works half as well. I buy them in large sheets and cut them down to fit into flat hand sanding blocks with the keeper ends to hold them on. You won't make an impression with your fingers removing to much material that way.
You can get the rotary air tool pads and I use them as well but be careful not to remove metal with it.
I personally install the clips at the 6 position in all raw water cooled marine applications, haven't lost one yet.
One thing I noticed that WSM circlip is almost identical to the stock one except the stock clip has a bend at one end which stops the circlip from spinning in side the groove.
Shop manual requires the bent end sitting inside the groove opening. The WSM clip requires the clip facing up, so they assume that the clip won't spin?
I used the old piston to practice circlip installation. I can install the first circlip with the piston out no problem. But when the piston is in place, it will be tougher job to get the second one in the groove. With some practice pretending in limited space, I can get it in confidently now. It seems like a 1/4" flat screw driver and a 3/4" screw driver or dull chisel is the trick. And the screw driver needs to be sit against the 90 degree step, not the other side, which is a slippery slope.
Will try on the new piston soon after I use gasket remover to give the crankcase gasket surface a final clean.
I hope my theory works
The clip should be so tight it doesn't spin. I think if it's lose enough to spin then there's something wrong and the clip doesn't fit properly.
Maybe a sanding drum on a dremel for doing the port radiusing? Remember, Jennings only used files, he thought a rotary tool or die grinder was too dangerous.
One of the WSN rings got the top and bottom side coated black. Which one should be on the top? Someone said it doesn't matter?
