There is some history to this problem if you search for (2001 GTX from Borger still will not run)
This machine would not pull fuel into the carb. If I sprayed fuel mixture into the carb it would run. I tried all the things that this site advised me to do up to a point where I got too frustrated with my ability to repair my 2001 Seadoo GTX, so I found a repair shop in Oklahoma. I delivered the Seadoo on May 11 and they thought they fixed the machine on August 26, but when I arrived there was another problem.
While in the shop, they removed the carbs and put them in some electronic cleaner to remove all dirt and junk. They found a hairline-crack in the intake nozzle on the PTO carb. That nozzle was replaced. All new carb kit parts. It fired right up. They called and said they wanted to do a on-lake test, so I started driving to Oklahoma (2 hour cruise). When the mechanic returned from the lake he said that as soon as the Seadoo touched the water it died. The Seadoo would run by hose but not with the full load of the lake.
I also had my Yamaha 800R looked at. They lake-tested it as well. The mechanic said it would start right up but would not power up much more than an idle. The mechanic said that the Yamaha has a "guardian" which I understood to be a computer code that protects the engine from further damage but will allow you to limp back to the boat dock. The mechanic did not know if the Seadoo had a guardian.
I mentioned to them that there was a "jet" in one of the small carb fuel lines and they never heard of it. When they reassembled the carbs they could have put the fuel line on backwards with the jet in the wrong direction. The jet could have fell out of the fuel line. The jet could be in the fuel line but may have turned sideways. I don't know because it was after working hours and I haven't heard back from them.
The Seadoo starts right up and will accelerate like I remember it did. I do not know if this jet plays a part in the engine dying when put under the full load of water of the lake.
It has been 3 and a half months since I took the Seadoo and Yamaha into their shop and not sure what to do at this point so I am turning to my good friends on this forum. Anyone ever heard of a guardian? Anyone have any advice on what to try. By the way the Seadoo has 25 hours of run time and the Yamaha has 21 hours of run time.
Please help... I would sincerely appreciate your advice.... Scott from Borger TX
