RESTO 2001 gtx di checks
cbonner70
Hey guys I am new to the forum and have recently purchased two seadoos. One is a 02 GTI LE which runs good. Other is a 01 GTX DI which PO said needed top end. Before I haul off and get in to engine what are the recommended checks to do in order to properly diagnose the problem?
Exactly as Jimmy said.
Compression needs to be 140-120 and at 110 it is done.
Fuel pressure has to be exactly 107 psi.
Wow 60 and 30 respectively definitely shot. Did hear a hissing noise after turning engine over to check compression. Not sure if bad gasket or worse. We’ll see when I can get it in the garage to remove.
