I'm another newbie to the forum so please have patience with me. I've got some mechanical system capabilities but not much in the way of engines. Have been using my 2001 GTI with the 717 engine on the water this season with no problems. Spent a full day out earlier this week when headed to a different place to refuel. When approaching the fuel dock noticed plenty of milfoil to manuever around but apparently sucked something in because the engine began to smoke. A glance at the water outlet port on the side of the craft showed no water. I quickly cut the motor and pulled some vegetation out from the intake. Before refueling I decided to make sure everything was okay so idled back out. Unfortunately when applying throttle the engine would only sputter and I had to cruise back to the ramp at 5mph which took an hour. Water was circulating fine. At home I pulled two plugs and both were fouled (very black) and replaced them with the correct NGK plugs gaped at .018. Engine cranks right up but sputters so I quickly shut it down again. I'm replacing the fuel filter this evening but suspect something else is wrong considering all this happened after an engine overheat. The DESS only does the expected two beeps when attaching the lanyard and there are no other beeps. There were no beeps either when the engine started smoking. Any suggestions would be greatly appreciated as I hesitate to take the pwc to the shop due to notorious overcharging. Thank you!
