Royce
First off my XP is converted to premix has clear fuel lines with a external fuel filter as well as the stock one in the bowl.. Now when it sits for a bit fuel seems to fall back toward the tank.. It has a prime but when I prime it it does not fell like i'm doing anything the prime moves too freely.. I must crank it for a few mins as I watch the fuel slowly come from tank threw bowl filter (bowl stays full) dn threw in line filter and down to carbs once its there it fires up and runs like a raped ape!!! so long story hope I worded it good enough for you guys to help... is it the prime?? is there a type of low pressure fuel pump thats bad??
On a 2nd note the fuel gauge is out and I check the gauge it self for good connections and the correct wiring (because it has race bars and the speedo just wasn't plugged in when I got it) thats good so I assume sending unit!! Now I read in manual there is a fuel reserve that gets you another 11 mins of riding time!! is this like a motorcycle IE: when you run out you flip a switch somewhere and get enough ride time to get you home??
