Hey guys...hope you can help. My issue is high rpm's with no speed but if I feather the throttle I can get it up to speed and it maintains the speed until I let off. I had the ski in the water and ran great and then all the sudden rev'd high and lost speed. I got it to the dock and found it was filling up with water. The carbon ring had slipped back into the rubber boot and was not sealing the shaft. I pulled it back up and put a new clamp on it. Now out of the hole it revs high and barely moves. I pulled the pump when I got home and the cone was full of water instead of oil. Everything seems ok on the pump assembly so I filled it with oil after draining the water and letting the pump dry out. I bolted it all together and still high rpm but won't go unless I feather into it. Here is what I have noticed today...
1.carbon ring has slop on the shaft...is this normal or should it fit snug on the shaft.
2.joint support with the grease fitting rotates freely and moves in and out slightly...is this normal as my buddy has a 97xp and his joint support will not rotate or move at all.
3.while out of the water on the trailer if I start the ski it seems as if the shaft is bent at idle but if I gas it slightly it seems to smooth out.
I did suck up a ski rope about 3 trips prior to this one that was pretty nasty but I got it all out and the ski ran awesome after that until now which has been about 2-3 hours ride time. I'm guessing its a bent shaft from when I sucked the rope up and caused something to fail. Please let me know what you think I should try next.
Thanks again ,
Tony
Thanks again ,
Tony
