new_found_power
I had taken my engine out to replace the bendix, (engine, carbs and all) I disconnected the throttle cable. I also put the oil block off kit on, now I'm trying to put the throttle cable back on the carb, I looped it around the valve arm and tried the throttle, when I squeezed the throttle the valves opened properly, but did not close when I let go. The throttle was still wide open....
Does anyone have pictures or information on how the throttle cable should go, or how to fix the problem?
