scarth 2000 xp
have a 2000 xp with carbs. have the oil block off kit. i got the oil pump off and im confused now, there is the hose with the spring inside it with oil running through it from the oil reservoir, and then there is the two small lines going to the pump as well.
How do i hook up the oil line to the rotary valve to keep it lubricated?
They block off kit i have came with the blue block plate, 2 screws, 2 washers and 2 little plastick block off caps, could you please help me figure this out and get me ski running and on the water.
Many Thanks, Andy
Many Thanks, Andy
